gregpurcell
Greg Purcell
This is a used set of 318 "Spool Type" motor mounts for a 73 up A B F M J body. These are NOT conversion mounts, you must have a factory small block V8 K frame to use them.
The driver's side may also work with the narrower 340 360 ears with shims.
The ruber insulator on these is the original Mopar part number. There is some heat cracking but they may still be usable. I also have the long bolts that mount the engine to the K frame with this set.
Located in Savannah, GA I need $25 plus $10 for the ride.
Thanks for looking!
Thanks for looking!
