73 AC clutch wiring
furz4
Marion, Iowa
The AC was removed from my car and I am updating with modern components. Where does the clutch wire come out of the wiring harness? I know I have the original harness but it was re-taped and I am wondering if maybe they cut the plug off and just taped over the wire.
Should be up near the alternator and coolant temp. sensor connectors.
The low pressure cutout wires should be further back near the coil connectors.
Sorry I can't tell you the color codes right now, but you should be able to download the wiring diagrams over at MyMopar.com .
For starters you need to post just what is "my car." If you do not have one, run over to MyMopar.com and download the closest year/ model service manual you can find there. You may have to accept Plymouth vs Dodge, etc. Also go to the wiring section and download the aftermarket diagrams. Those are not as complete or detailed, but CAN be easier to follow.
Several of the manuals over there !! got there !! because of the guys right here.
