[FOR SALE] 73 dodge challenger hemi project
penski61
mesa
Too many projects so I need to either sell this or another car . 1973 Dodge Challenger with body work 80% done just finished opening up the trans tunnel to fit a 6 speed tr6060 transmission and getting the patch panel done . Has a gerst coilover conversion tube front k member , upper and lowers (not installed) new spindles but needs rack and pinion , coilover and brakes . Rear is triangulated 4 link with 35 spline Dana 60 3.55 gears and disc brakes or I can put an early b body 8-3/4 back under it with leafs for cheaper . The car is setup for a modern hemi and the 6 speed manual (needs pedals and trans cross member made). I have a 2014 5.7 hemi swap with 36k on it and a car intake that will come with the car as well as the tr6060. Almost all parts are there as far as I can tell . pm if you have any questions, car is located in Mesa , Az
asking 12k or 9k without engine and trans
updated some of the images and also got the sub frame connectors installed
