RIBOATSERVICES
I decided to go with overdrive so I set the original a833 trans aside and hunted down a few a833 overdrive trannys.
It definetly takes a while to get used to the feel of the diaphram clutch.
ThhI just saw your thread this morning and read it from start to present. You have done a wonderful job on getting the '73 back on the road. Are you a hobbyist or do you have bodywork experience?
Your car looks beautiful. Pat yourself on the back for a job well done.
Thanks for the kind words! Just a hobbyist, I had not done any bodywork in over 30 years, but restoring a car in that bad a shape completely by myself really teaches you a ton. I know i probably should have restored it back to it`s original factory build, but i can always do that later if these A bodies start to climb in value one day! Cant wait to start on the 71 Duster and I have a sister car to the 73, its a 73 340 automatic with A/C, I bought it for my wife (but she probably wont drive it, no power windows Now if i could only hit the lottery so i can buy some more parts!I just saw your thread this morning and read it from start to present. You have done a wonderful job on getting the '73 back on the road. Are you a hobbyist or do you have bodywork experience?
I used the stock bellhousing to fork spring, removed the over center spring and replaced it with a very light weight spring to help keep the pedal up all the way.RIBOAT- What did you use for a spring set up on your Diaphram Clutch set up?
I gotta try to get some better pics.FANTASTIC JOB would love to see more than just the back side of it tho PLEASE
Wow you did a fantastic job !!Thanks, it`s come a long way!
Thanks! Your 73 looks great!Wow you did a fantastic job !!
Thanks! Ya, i`m not really sure about how the over center spring helps pull the pedal down, i think there is some black magic in how that works! But the small spring on the clutch fork isn`t strong enough to keep the clutch pedal all the way up against the bump stop, it had about an inch of slop at the top that I hated so installing the soft spring in place of the over center spring holds the pedal up high and has no effect on how the original spring worked.Wicked awesome Duster! glad I could help. I thought the overcenter spring helped pull the pedal down?
