A little info about that for you from someone who has been through it.
You can get the OEM harness new with the signal cam assembly as a complete unit, but they are a little pricey.
You can also get just a replacement cam "switch" as an aftermarket part pretty cheap.
The problem is the aftermarket part is usually not made with the exact same tolerances as the old one is, so it has to be tweaked to work right.
In my own case I got the aftermarket cam assy and had to tweak the contact wires to get it to correctly control the signals.
As is it caused the flasher unit to flash/click with the left signal on but no lights came on or flashed, and the right signal wouldn't stay on unless I held the lever in position.
Others have had these problems with the aftermarket (switch only) replacement.
Point is, you would be miles ahead just getting the OEM part with the pigtail/harness complete.
Slant6 Dan (/6 Dan) had some of the OEM complete units for sale here before and may still.
