[WANTED] 73 Duster Blower Switch and Heater outer box w/ac needed
SLODuster
Member
Lompoc
Rating - 0%
0   0   0
It seems the correct 3 prong 45 degree terminal switch for the 73 Duster commands a lot of money. I was looking at other options and just running terminals to like a HS201 or HS203 new style switch. I searched but didnt find anyone posting this issue.
I also could use the front heater portion of the heater box. Mine has broken pieces around it and my car has A/c.
Thanks Brian
Are you speaking of the low/med/high fan switch? I have a NOS one.
What outer box are you speaking of?
I pulled my 73 Duster box with a/c out and took it apart to put in a new heater core. I am not going to put it back in. If you want pics, please pm me your email
I also have a complete box that I do not intend to use.
I ended up using a later model switch BL2 BWD i put another thread on the forum about it. Working ok. For time sake as I need to get it back together Ill reform and repair the panel on my existing unit. The part is the one that screws on covering the heater core.
