73 duster in Georgia
ironmonkey
georgia
Rating - 0%
0   0   0
I am selling my 73 duster. It has a lot of work done to it, its a 318 modified has a mild cam 340/360 heads , body work has been done... just needs a little fine tuning, floor pans have also been replaced. Other NEW modifications that are already in the car are follows:
Tank, fuel lines , fuel filter, sending unit , fuel pump and 670 Holley 4 barrel
Dipstick tube and stick
Alternator
ALL belts
Battery pos and negative lines
Starter
Mopar performance valve covers
Front shocks
New tires has rally wheels 14" front and 15" rear
Front end alignment
Voltage regulator
ECU (electric control unit performance up to 10,000 rpm)
Mallory performance coil
Tune up with royal purple oil (cap and button and plugs and wires)
Lucas oil in transmission and rear end
PVC valve
Chrome 14in low profile air filter
Clutch ( fly wheel was turned when installed)
hurst pistol grip shifter
Z bar bushing kit
U-joint in drive shaft
Oil pan, high flow oil pump, windage tray
Conversion kit from points to electronic ( not installed )
also a 4 speed trans ( not installed )
Check out some PIC's of the car at:
click this
http://www.photobucket.com/duster_photos
I also have a some extra parts that will be included in the overall sale.
I'm asking $5,000 OBO
If you have any questions please feel free to contact me via e mail, xxxxxxxxxxxxxxxxx or my Cell: xxxxxxxxxxxxxxxxxThanks
Wlliam Turner
Alternator
ALL belts
Starter
Front shocks
Front end alignment
Voltage regulator
PVC valve
Z bar bushing kit
click this
If you have any questions please feel free to contact me via e mail, xxxxx or my Cell: xxxxxxxxxxx Thanks
Wlliam Turner
