bmcentir
73 duster
Any one out there that might have some experience with installing new door seals/ or have some advice would be helpful. I have the glass in with the all new window felts and door seals. When I roll up the window and close the door the new seal that is on the channel above the window on the roof... Causes the window to push out away from the seal. Is this normal or is the seal not right? It just seems way to tight and not completely sealed. Do the new seals need to sit and compress for some time or ?????
I could barely get the door to close with the window in the up position. Any advice or help would be appreciated. Brad
