Howard1784
Mopar Performance crate motor 380 hp Part # P5249499
Stock heads replaced for Eddy aluminum heads 202/1.60. Ported, polished, gasket matched
(Still have stock heads and valve train)
Comp Cams Roller Rockers and push rods
M1 Intake ported and gasket matched
TTI Headers w/ Magnaflow mufflers
Holley 750 DP
Dual electric fans
904 trans w/ RMVB, 3600 -3800 stall
Ford 9 in rear, posi, 3.70 gears
(4) superstock brake lines
4 new QA1 shocks
125 NOS (not used) with extra full bottle
New MSD 6A ignition box
All the plastic dash bezels have been rechromed and restored. The heater delete bezel is not included but an original restored one is
New ABS headliner, door panels and dash pad
New under dash wiring harness
Retro Radio and speakers w/ power antenna
Frame connected
New windshield, NOS windshield gasket
Body was taken down to bare metal, repaired and repainted. There is not an ounce of rust on this vehicle. I bought the best doors money could buy as well as fenders for the car which were exceptionally clean and straight. AAR bolt on fiberglass hood w/lightweight springs
I have extra jets and squirters for the carb as it will need to be dialed in correctly. 3 pairs of extra doors go with the purchase along with (2) new door skins. Every single part I have goes with the buy.
There is less than 200 miles on this motor and it has not been broken in which is why the NOS has not been applied. The car has not been raced and regularly garaged. Car is in Manassas, Virginia 20110. $25K or Best Offer. Fridays/ Sat. are the best days to see the car
Pics
Holley 750 DP
Dual electric fans
4 new QA1 shocks
Frame connected
Pics
