[FOR SALE] '73 Swinger 440 project
cletus
Cooter's Apprentice
Sedro Woolley
Rating - 0%
0   0   0
'73 Dart Swinger 440 project
$4500, local pickup only, I will not ship it. I'm in Washington State. You can come over and hear it run.
New engine:
'78 440 punched .030 over
original cast crank & rods
Speed pro +7cc forged pistons
Federal Mogul rings & bearings, Moly top ring
*Internally Balanced*
High flow oil pump
Fel Pro gasket set
MP cam: .484 lift, 241 duration @.050 lift, 108 lobe separation
Comp Cams double roller timing set
'516 casting heads from '65 383, hardened exhaust seats & new 1.74 exhaust valves installed with bowl blend.
Eddy Torker manifold, Eddy 750 carb with electric choke.
MSD 6A.
Taylor 8.2mm wires
MSD Blaster 2 coil
727:
I don't know the history of the transmission. It was mated to the engine when I bought it, as far as I can tell it has a stock torque converter on it. It seems to work well and shifts solid.
B&M Z-Gate shifter.
Rear end is a 8 3/4 from a different vehicle, I had the spring perches moved in for the Dart, 3.23:1 posi center section. Rear end is wider than it should be for this body, I put 17" wheels from a newer Mustang on it so they would be inside the body. (they look like American Racing wheels) I have a pair of matching wheels for the front with spacer plates to make them fit, but no tires.
Body is rough. Fuel filler shaved, moved into trunk. New sheet metal in the floor, but the exterior all needs done.
Interior is in pieces, I don't have carpet or a headliner for it. It has bucket seats in it from a mid-90's Ford Explorer, I have the rear seat (it's got a couple tears), and I have a set of grey and black seat covers that go with it. I died and painted the interior panels I have black.
Door glass and 1/4 glass all still in the car, windshield and back window have been removed, but I still have them and I have new gaskets to re-install them.
I still have all the original wiring to clean up and put back in it. I have some extra parts that will go with it.
If you are thinking about throwing me a low ball offer, consider how much it would cost you to buy a new crate engine that makes the kind of power this engine does.
I have already posted some pictures of this thing, look at my previous posts.
I feel like I may be forgetting some details, PM me if you have any questions.
I really would like to finish this, but life seems to be getting in the way.
Thanks for looking.
-Steve
Maybe I missed it but did you say how much power the engine makes?
It's never been on a dyno, my best guess is 450ish. My old man rode in the car with me and says I could get away with telling people 500, but that would be a lie.
A few pics...
