I got this with the car I bought. I did not need them. Schumacher makes them and the text is from their website. One bolt is substituted others are original
Ask any questions. Price at scumachers is $159. I will take $100 plus shipping. From Idaho
Bolts the Big Block 383, 400 or 440 engine to factory specs on your original S6 '73 and up A, B, F, M, J-Body (and '74 & up C-Body) K-member. Kit includes laser-cut, powder-coated brackets, urethane inserts, grade 8 bolt package, and detailed, illustrated instructions. Applicable to cars with or without power steering.
(see installation instructions and tech tips)
NOTE: The driver's side mounting perch on the '73 & Up K-member interferes with any V8 block and B/RB oil pump. To eliminate this problem, the driver's side engine mounting perch needs to be drilled with 9/16" holes and excess material must be removed. This effectively lowers the perch and is detailed in the instructions.
