[SOLD] 74 DART SPORT 360 4 SPEED
74 360 dart sport
Montevideo Minnesota
THERE ARE TO MANY THINGS I HAVE DONE TO MY CAR TO LIST BUT IT IS IN ITS ORIGINAL GLORY ALL ORIGINAL PARTS I HAVE KEPT EVERYTHING FROM FRONT TO BACK ON SUSPENSION HAS BEEN REPLACED MOTOR HAS LESS THEN 150 MILES ON IT CAR HAS 45000 MILES ON IT LET'S TALK THANKS TOM 15000.00
Engine/trunk/undercarriage pics?
Can you give us details on the drivetrain build also?
Yes
I can get pictures tonight the engine is original # matching to the car it was built by sturdy racing engines Milbank south Dakota it has 150 or less miles on it it was dyno tuned and 4 pulls on the dyno 515 h.p. with 567 torque it has aluminum heads intake roller rockers h beam rods 4340 crank tti polished ceramic coated headers new complete wildwood front brakes new tires all new 18 way adjustable shocks new hellwig front sway bar new delrin bushings and pins from Bergman autocraft new upper and lower control arms put in new manual brakes from Cass at DR.DIFF. new leaf springs new gas tank new 8.75 suregrip 3.55 gears new electric fuel pump with all new braided fuel lines 2 micron fuel filters new fuel regulator new quickfuel 750 double pump new alternator new mini starter new carpet original rims all primed and painted all new 3 inch dual exhaust from the 3 in. Collectors back with new mufflers probably a lot more that I'm forgetting about trunk is rust free but I started painting it with por15 wished I wouldn't have but it's only partially done tire well is rust free new McLeod dual clutch kit the motor was blue printed the builder said it is completely straight squared balanced I have over 9000 in the motor
I will get pictures of the inside of the trunk tomorrow but it is rust free it also has new hotchkis subframe connectors msd ready to run distributor new blaster coil new aluminum radiator with 2 electric fans and shroud from cold case new interstate battery the whole front and rear suspension is new everything
