dustya_383
Hey guys I have here for sale my 74 plymouth duster .
360 smallblock bored over.040 stroked to 410ci*
4inch scat crank
Balanced*
Scat con rods
Probe industries pistons*
Block work done by Ellsworth machine shop in mountain view*
Indy rhs heads ported ,flow 290 cfm have flow chart from Imm engines in Indio Ca
Manley valves 2.02 1.60
Beehive springs
Hughes 1.6 aluminum roller rockers
Hughes aluminum fab valve covers
Magnum 306s solid cam comp cam 260@50 .555/555 lift 306 duration*
Solid comp cam lifters*
Comp cam pushrods*
Edelbrock air gap intake ported and gasket matched to heads*
Proform 750 dp carb (needs a good tune)
Dougs ceramic headers great clearance*
Mini starter
Summit 3 inch xpipe
Hooker header aero chamber 3inch mufflers
Msd*pro billit distributor*
Msd wires 6al box with built in rev limiter*
Hv oil pump*
Hv aluminum water pump*
Kevko racing oil pan*
A833 4 speed transmission*
Centerforce dual friction clutch*
440 source flywheel
Lakewood scattershield with block plate*
New balanced driveshaft*
Heavy duty u joints*
8 3/4 rear end with 3.23 suregrip 489 case have 3.91 ring and pinion as well*
Moser axles with green bearings
3 inch screw in studs*
11 inch rear drums*
Fiber glass 6 pack lift off hood
The*
Roof was damaged by previous owner
Car was painted primer black by previous owner Original color is a b5 blue*
Has no carpet .. I Removed it as it was original and smelled bad*
No headliner Has door panels and such and trim .
No dash pad owner did some Nasty bodywork I bought car just to drive Had a 318 904 8 1/4 in it .. then ended up swapping my drive train into it*
very fast fun car to drive I have 2 project so need to get rid of both
Asking $9500 for complete car or 6k for engine carb to pan
Just under 3k miles on engine in the last 3 years*
Have plenty of receipts for work done*
Really don't want to sell but need to right now
Stephon
Some of you know I have a lot invested in this and hurts me to sell .
Also I will sell a rolling shell for $2200
Comed with an 8 3/4 with axles no center section at the moment long tail 727 and a 440 long block that needs to be gone thru
For some reason I cannot post more than 1 photo so I will continue posting pics right after
Thanks guys
4inch scat crank
Balanced*
Scat con rods
Beehive springs
Comp cam pushrods*
Mini starter
Summit 3 inch xpipe
Hv oil pump*
440 source flywheel
11 inch rear drums*
The*
Stephon
Thanks guys
