What strut rods did you run i have been looking at the firm feelTheoretically, but it isn’t much. Plus I have fully adjustable strut rods so it would not matter.
If you are using stock style bushings you can cut the same amount off the bushing by the washer side so it will even out, if using adjustable struts then as mosleyme said, it doesn't matter.By adding thickness where the strut rods insert into kframe does that have any effect on their adjustment etc as essentially spacing them out with the welded washers?
O that makes sense, i do like the firm feel rods as look nice and strong and quite simple compared to the PST ones etcIf you are using stock style bushings you can cut the same amount off the bushing by the washer side so it will even out, if using adjustable struts then as mosleyme said, it doesn't matter.
If you are talking the LCA pivot pin, then you are fine to re-use as long as it isn't bent. The factory one is a nice forged piece.About to start rebuilding the suspension, i have the PST graphite kit that has all the balljoints and rubbers etc. Do i need new pivot pins or just re use the original with new bushes etc? Is this an item that wears out? As new pivot pins are not cheap given what you are getting. I will also brace and powder coat the arms.
Anything to look out for with the arms etc?
Yep thats the one, as for what they cost rather get new mirrors lol. As this car pretty much every part either brand new or reconditioned. Hopefully all worth it haha. Watched a few videos on rebuilding the arms so i will do this soon.If you are talking the LCA pivot pin, then you are fine to re-use as long as it isn't bent. The factory one is a nice forged piece.
I cant figure out whats going on, my 1-59/64 fits my new upper ball joints perfectly however it doesnt fit the original bal joints.
Its like its the slightest bit too small, the round section before the square sides fouls on the socket. Its probably only out by a few mm at the most.
But from what i have read 1-59/64 is the correct size?
Thanks for the info actually did exactly this before i seen your post. I got my grinder and gave the sides a kiss and tap of a hammer the socket fitted. Was odd the round top was overhanging the square sides, like had been hit or maybe wrong tool usedAre you using a standard socket?
Original is not. I have removed them in the past with a pipe wrench... not advisable. Which is why I have the correct socket now.
Oh, and much easier to do it while the control arm is on the car, need some leverage.
Socket:
My upper ball joint:
Let me go measure... you may have the wrong size. Mine measures 1.92". 1-59/64" sounds correct. That is correct for the '73-'76 A-body.
Did someone damage the prior joint, just need cleaning up with a file or dremel?
Measure across the flats. I seem to remember in the past actually having to tap the socket on with some cars because it wasn't a perfectly clean edge.
Thanks, it was a slow process, however got the underside to fit like factory that i notice many people cant get. Actually had to slit the quarter and shorten at the bottom to get it all to work. Now about to start getting the gaps spot on.Rock and roll brother. I like good fit and finish and the q/p to rocker is tough. Looks like ypu got her though.
nice work, i've always thought it was daft to have that step too. unfortunately (stupidly) it's not just mopar's that are like it![]()
Think you may be on to something here!! Back in those days they were not thinking someone would run a 275 rear. Either way its no issue now with some cutting and patching. Few burnouts and will be covered in rubber anywayI think it is a carry over from the Valiant/Dart. When they widened the back and created the Duster, they didn't want to create a completely new part so they just stepped it to get it over to the quarter. But just my guess.
Nice work, definitely something to fix. Planning to do something similar at some point to my G3 car.
