74 Duster removing drip edge chrome?
dusty1
How is the best way to remove the chrome strip off of the drip edge over the doors? Do you use a screw driver and slide it length ways or does it roll off from the top or bottom? Any help would be appreciated. Thanks.
I used a screw driver carefully working the top edge off first, once you get it going it comes off fairly easily. This was on a dart, but a duster should be about the same I'd guess.
