dustya_383
Looking for a 67-69 fastback barracuda small or big block 4speed running condition some body work ok no rust repair I'm in California .
74 duster trade or sell 9kfirm
360 smallblock bored over.040 stroked to 410ci
4inch scat crank
Balanced
Scat con rods
Probe industries pistons
Block work done by Ellsworth machine shop in mountain view
Indy rhs heads ported ,flow 290 cfm have flow chart from Imm engines in Indio Ca
Manley valves 2.02 1.60
Beehive springs
Hughes 1.6 aluminum roller rockers
Magnum 306s solid cam comp cam 260@50 .555/555 lift 306 duration
Solid comp cam lifters
Comp cam pushrods
Edelbrock air gap intake ported and gasket matched to heads
Proform 750 dp carb
Dougs ceramic headers great clearance
Mini starter
Summit 3 inch xpipe
Hooker header aero chamber 3inch mufflers msd
Msd pro billit distributor
Msd wires 6al box with built in rev limiter
Hv oil pump
Hv aluminum water pump
Kevko racing oil pan
A833 4 speed transmission
Centerforce dual friction clutch
440 source flywheel
Lakewood scattershield with block plate
New balanced driveshaft
Heavy duty u joints
8 3/4 rear end with 3.23 suregrip 489 case have 3.91 ring and pinion as well
Moser axles with green bearings
3 inch screw in studs
11 inch rear drums
Fiber glass 6 pack lift off hood
The
Roof was damaged by previous owner
Car was painted primer black by previous owner Original color is a b5 blue
Has no carpet .. I Removed it as it was original and smelled bad
Has door panels and such and trim .
Great for a weekend racer
4inch scat crank
Balanced
Scat con rods
Beehive springs
Comp cam pushrods
Proform 750 dp carb
Mini starter
Summit 3 inch xpipe
Hv oil pump
440 source flywheel
Heavy duty u joints
11 inch rear drums
The
