74 Swinger, SW Ontario
project74
Windsor, Ontario
Rating - 0%
0   0   0
Too many projects so one has to go.
1974 Dart Swinger, originally a /6 car, engine and trans pulled for a V-8 conversion. Car needs reassembly but is VERY complete. All electricals and such worked fine before disassembly. Extremely solid with no holes or soft spots anywhere in the frame or floors and very straight panels. Previous owner did some body work on the rear quarters and did a pretty decent job. Still needs body finishing and paint. Lots of new parts including rear KYB shocks, all glass trim clips, firewall gaskets, body plugs and more. Near new BF Goodrich radials mounted on a set of really nice SBP Rallyes complete with caps and rings. Included also is a running '73 318 recently pulled from a '73 Wagon and a small block 904 that needs to be gone through.
Asking $3200 CDN. Car is located in Windsor, Ontario. You won't find a straighter more solid Mopar project anywhere in this area. Call 519-560-3717 and ask for John. Thanks for the ad FABO
