74 truck 360 for a 70 dart
kutter79
Active Member
st. charles MO
ive come across a 74 360 out of a truck. guy said it ran when he pulled it. it is complete. i can get it for 200, is that pretty good. will it swap into my 70 dart with minimal problems, have heard things about oil sump and other little things. thanks for the help.
i also have a 360 from a 74 pick up and you will have to change the oil pan.. you also need a V8 k frame unless you already havea V8. its differet from a slant k frame..
as for 200.. i got my motor and 727 tranny for 300
theres other things like ignition and exhaust things that you will run into.
are you going from slant 6 or 318 to the 360?
Schumacher makes a good kit for engine mounts.
As Cerwin said, you will need a car oil pan,
and the car oil pump/pickup.
car already has 318. i have also already put electronic ignition on it. what type of ignition will i have to change. thanks
