75-76 Cordoba Brake's
Dodge33
Bellevue, Mich.
I've got a set of these brake's, and they come from a Cordoba with a 360/ 727 combo. I thought all of the Cordoba's had 11.75 rotor's installed from the factory? I also read somewhere that just the factory BB car's came with the bigger rotor. Could any of you fellas get me updated on this, as all help is appreciated.
76 on up Cordoba's, Magnum's, are the ones that got the 11 3/4 inch rotors.
The 75's did not.
Nope. They had 10" brakes as well. What I wanna know is if the bigger brake calipers from the 80's trucks will interchange with the 'Doba
No, they won't.
They are too "big" to fit.
They won't bolt up to the spindles.
The bolt hole, mount spacing is different.
