Sixpack_Sid
I have been having trouble with my front brakes locking up. I replaced the brake hoses and the calipers. I ordered new rotors and pads. When I put tried to put them on, they wouldn't fit on the rotor. It's almost like the pads are too thick. When I matched up the new pads, the one pad is thicker than the other. That may be why the pad won't fit on the rotor. Is that common? Anyone have a recommendation on what brand pads to buy that will fit? Or should I cut my new rotors down?
RAYBESTOS MGD84M Specifications | |
Friction Material | Metallic |
Pad Assembly Thickness, Inner Overall (IN) | 0.225 |
Pad Assembly Thickness, Outer Overall (IN) | 0.165 |
Plate Length, Inner (IN) | 5.610 |
Plate Length, Outer (IN) | 5.610 |
