burrpenick
'69 Barracuda
I know they had lower compression, altered cams/timing etc, along w/large pattern wheels and front Discs. But other than the HEAVY BUMPERS, what else is actually different?
Yes, they are very similar, but I was getting at more of the performance issues like mentioned detuned engines and extra weight. Seems to be like 300+ lbs more for the later model.There would be a lot shorter list if you would ask what is the same. And they are very few cosmetic items.
I don't think there is a horsepower advantage for a 318 in '71 to a 318 in, lets say, '74. In general, the '70-'72 Duster are lighter, but not if we are talking the "feather lite" Dusters in '76. Also, options make a difference. No performance advantage in the transmissions, and rear ends are just a matter of which gearing. Of course, the early year Dusters could be optioned with a 8.75 rear vs 8.25 in the later years. Both early and late years rolled out millions of 7.25 rears in the Duster. Obviously, the newer ones had cats.Yes, they are very similar, but I was getting at more of the performance issues like mentioned detuned engines and extra weight. Seems to be like 300+ lbs more for the later model.
I have always thought they should be divided into generations.
Gen 1 should be 70 to 72 and gen 2 should be 73 to 76.
Very little is the same between the two other than same basic shape and the duster name.
My 1976 duster 904 automatic has 2.45 first and 1.45 second gear ratios, same as the older cars. Wide ratios were not used until 1980 according to my transmission manual.most of the 70-1 cars with automatics had 904s, and so did the 75s, but the gear spacing was different - wider spacing of gears in the later cars. Later cars had lower 1st gears, somewhat lower second gears and the same 1:1 third gear. This was done to accommodate relatively high (numerically low) rear end gears (think 2.45:1). The lower first and second gears would cover up the high rear gears getting up to speed but result in lower engine rpms in third gear. You should figure out which gear set the 75 has before choosing rear gears (depending on your aims).
...and yeah the doors interchange between those years but they are completely different internally
85, I think. A godsend for the 2.26(!) gears in M bodies.My 1976 duster 904 automatic has 2.45 first and 1.45 second gear ratios, same as the older cars. Wide ratios were not used until 1980 according to my transmission manual.
