Justen newton
Member
I'm swapping engines in my 74' 318 dart custom to a 76' 360. I was wondering if someone could point me in the right direction for the correct pan and pickup tube used for this motor and car. Thanks for the help
It don't matter the pump is still the same. If it worked in the van it will work the same in a carI'm pulling the motor from a 1 ton Dodge van swapping into my dart
