This is turning into a career........
We got some more things done today...I got the fuel lines all plumbed....Got the passenger side header all bolted down...that was a pain in the ***....
Then ..what i thought this was a slam dunk ..but it was an air ball....the throttle pressure linkage....aka kickdown linkage...I figured i would use the one that came off the motorhome...it is a one piece rod....well ,,,,it hits the cab and wont fit....so dam...
I figured i was going to have to do a Dental Dart and order a lokar cable linkage....then I remember a few months ago I bought a complete set off ebay ..cheap...
So bingo it bolted right on....the 3 piece unit...with the bellcranks and all,,,,,
Still waiting for the cooler lines ..tracking number shows thursday.....i need to get some plugs...atf....put the distributor in....
and i have to tackle that front u joint ....got an idea....going to measure the front half shaft from the motorhome and see if they are the same length....
