gtsdude
78 Dodge Aspen, original 318 car from North Carolina. Looks like an R/T but has a 340 under the hood. Has an 8 3/4 sure grip rear end with 3.91 gears. 904 transmission with reverse manual valve body and 3800 stall Coan converter, hooked to a B&M Pro ratchet shifter. Motor is a 73 cast crank, with the early advertised 10.5-1 pistons. Heads are 587 castings, that are factory 1.88 intake, 1.60 exhaust valves. Cam is a Mopar Performance 497 lift, 245@50 hydraulic cam. Hooker competition headers, Holley Strip Dominator intake, Holley 650 DP carb. electric fuel pump. New front tires. Interior is all there but the carpet, it is out to repair few small holes in driver side floor. Has Bucket seats that are white and need covers and original rear seat in good condition that is blue. Will need a dash cap. Body has some patch panels but unibody frame is in good shape. Has rear side window louvers not installed. Runs and drives good. Car is located in Spring Valley, MN 55975, asking $3500.
