[FOR SALE] 8-1/4” BBP package
Syleng1
Karma is real and Life is short...
North Franklin, CT
$1000.00
Up for sale in Southeastern, CT and pick up only. I’m 1/2 mile from Mohegan Sun Casino in Uncasville. I don’t need the money so it can sit. Listing here first before local FB or eBay.
All parts listed as new have approx 1,000miles on this assembly. Works flawless.
Car: 1974 Dodge Dart 318 auto car with 40k.
8-1/4” BBP, 10”x2-1/2” drum brakes.
New axles bearings and seals
New pinion bearing and seals.New carrier bearings. New mechanical locker 2.45gears (left alone. Good wear pattern)
Rear axle was built for break in for my 1966 Barracuda I built and once I hit 1,000miles I removed this rear and dropped in a 8-3/4 with better gears.
Also, This comes with all Napa brand new( still in boxes) finned drums, new shoes, New spring and new hold down kit, new adjuster kits. Both New e-brake cables, new wheel cylinders and the rest of the factory hardware that was sand blasted and e-primer and black painted. Housing was sand blasted and e primer and painted gloss black. Before I reassembled this axle. The diff cover and fill plug is new Chrysler parts department. Oil is Castro’s 80w90 oil.
Any questions please pm me. Thanks FABO for the ad.
