ValiantMike
I changed out an 8 1/4 rear for an 8 3/4 today because the 8 1/4 was too wide for my 1964 Valiant. The 8 1/4 was in the car when I bought it with car all jacked up so tires would not hit body. I'm hoping someone can tell me what it is actually for and how much I should sell it for. It is a posi rear with around 290ish gear, complete drum to drum.
It measures 44" center spring perch to center spring perch, measures 55" inside housing flange to inside housing flange, and axles are the larger bolt pattern. On the bottom are two lines of numbers, (3723599) and (10325).
I would appreciate any info anyone can give me so I know what I'm selling and what its worth. Thanks Mike
