Am I correct in saying that gears 2.71 and higher numerically and Sure Grips are interchangeable from any rear end up through 97, which IIRC, is when they went to a 29 spline axle? Reason I ask is I've acquired an A Body 8.25 peg leg with 2.71 gears and I'd like to upgrade it with a Sure Grip and higher numerical gears (3.21, 3.55 or 3.90s). The 4WD early Daks typically came with 3.55s and some with 3.90s (and are readily available in several local junkyards. OR, would it just b e better to go with readily available brand new stuff?
