slowdown
So I have a 8.25 with 3.55 gears not a sure grip. I know this is a for sale post but this is free to who ever wants to pick it up. It's been narrowed for a mini tube on a 68 dart. I originally had 8 inch weld wheels on it with 15x8 275 on it 4 inch back space. Then I had 15x12 draglite with mickythompson drag radials and everything fit. The spring perches have been moved in to mount on the frame. I'm not going to use this an with it being cut down, it becomes a specialty fit. So trying to selling it will just waste my time.If you plan on mini tub or trying to stuff fatter tires under your dart here's your free rear end. U can see pictures on my garage that's the 8.25 under my dart. I currently have a Dana 60 under it now so this isn't needed. Pick up only thanks.
