Blair Harris
Just looking for some advice on setting up an 8 3/4 rear end. I am replaceing the axle bearings and inner-outer seals in the housing. I also took the pot apart and exchange the spider gears with a posi unit. It is a 741 carrier 391gear had to change the yoke also to accomidate the 10 spline 7290 big joint. I have not set up a rear end for 25 years and cant remember how to shim the pinion and set ther axle adjustment on the passanger side.
Any help would be appreciated.
