Rapid Robert
Have: A body 8&3/4 housing shortened 1/4 on each side 52&1/8" OAL) by Moser. Chop saw shortened OE A body OE 8&3/4 axles. I can get the pass side end play down to minimum (~.010") with the adjuster but on pass side I had to take another cut with the saw & I think I went too far since with the b plate/foam/shim gaskets all in place & nuts tightened down I can move the axle in/out with the ~1/8" of free play that that side has like the axle ain't butting against the center thingie (which is in place/742 5:57 open welded spiders). will this be a problem with the OE tapered roller bearing not being "together" enough or possibly cause another issue (circle track app). I could source another pass axle & start over if needed. Your thoughts please. RR
