8 3/4 axle spline
bland15
Member
A 8 3/4 with a 741 case and it is a posi, what is the spline count on the axle? Thanks
Ace, can you tell me about your car? did you relocate your springs? narrow the rearend? what size wheels? I have a 71 duster.
Thanks
Sure, the springs are in stock location and the housing is a custom built unit made from a c-Body piece, 1/4" wider flange-to-flange than the a-body spec. It's got 15" cop wheels that fit just right with the tires listed in my sig. Maybe room to go 275 on the rear, but it doesn't need that much meat with the slightly over stock power it's making:
http://stuff.is-a-geek.net/PhotoAlbum/Cars/Pics/duster_36.jpg
