8 3/4" brake backing plates wanted 10"
moodman1962
Rating - 0%
0   0   0
Like the ad states, looking for a set of 10" backing plates with or without e-brake cables attached for 8 3/4" rear end.
Would be nice to find someone close to me for shipping purposes.Golden BC
Need to know the width of the brake shoes. The offset of the backing plate is different depending on the width of the shoes.
Stock A-body width in the rear was 1-3/4". If you aren't upgrading, that's what you need. I went BBP w/ 10 x 2-1/2 brakes so used B-body plates.
A body 8 3/4 rears with the factory small bolt pattern wheels have a different offset than other 8 3/4 rears. If you are going to big bolt pattern axles (aftermarket or B/C/E body) you need the B/C/E/Truck 8 3/4 backing plates. If you are using stock a body axles you need A body 8 3/4 backing plates.
NOW..what is it that you need?
