[FOR SALE] 8 3/4 Cone Posi Internal Parts
RRD
Active Member
USA Indiana
Rating - 0%
0   0   0
8 3/4 cone posi internal parts.
Side gears, very good condition - $60 pr
Side cones, will need cut as they bottomed on case. Cone surfaces in good condition, $50 pr
Spider gears, good condition but one is stuck on cross-shaft, $45 pr
Spring plates, springs, case bolts in good condition
Yes, that’s what typically happens. The pin hole gets trashed on both halves. Could be welded up and remachined if someone had the proper equipment.
