moparmarkk
hi,have a 73 duster,want to put in a 8 3/4 from a 66-67 b-body.i could not find the thread on this info,any help? thanks,mark
you could make life easier and install a 8 3/4 that came out of an a body.
cut off the springs pads, sit it on the springs and new pads, center it, install u-bolts and semi-tighten, sit hotrod on all fours on the floor, set pinion angle at 5-7 degrees to driveshaft, tack weld, jack hotrod back up on stands and remove rear, finish welding, put back in hotrod, buy wheels with the correct back spacing.
It's an easy swap, I put one in my 74 Dart Sport. I moved the perches in 1/2" on each side and re-welded them, bolted it in and I'm running 10" wide wheels with a 5 1/2" backspace. Works great.
