Brambles
My Dart already has the front BBP discs and the rear is a drum BBP 7 1/4 ( didn't think they existed?) I'm pieceing together a A-body 8 3/4, probably use yukon axles with BBP and want to upgrade the rear brakes. Discs will look better then drums IMO.
I've done a little reading and some guys have mentioned the Grand cherokee rear disc brakes, is this a direct bolt over or is there some foolin around to do? Does the E-brake hook up and work?
Are there other options for street cars?
I also have been sourcing bigger drums just incase I can't get a disc system together. I heard reference to some drums making it so you can't use some types of wheels, anyone got some info on this issue?
Thanks
Brambles
Thanks
Brambles
