[Found!] 8 3/4 rear
barracudakid
king nc
Rating - 99.3%
151   1   0
Looking for a complete 8 3/4 rear
Drum to drum or
As complete as possible
Gear ratio and carrier does not matter
As close to NC 27021 as possible
A body rear
A friend needs one hopefully within 2
Weeks
I have one in ohio all band new bolt in ready. 11" drums and 4.5 bolt pattern.
Price is $3600
Location is Collins ohio 44826
Eddie, I have one too. Perches moved in for MP relocation kit but have an extra set. SBP, Drum to drum 741 323 open pumpkin. I can send pics later.
South Dakota, freight might be a deal killer. I would get quote from Fastenal if possible.
I have one Eddie...comes with axles,housing,backing plates,3.23 single trac chunk $1,000 in SC
Got another one with a tweaked housing...can't get but one axle removed...other axle stuck in housing/chunk......$550..missing a backing plate
I have one. New drums, shoes, wheel cylinders, brake springs etc.. New green bearings. Posi was sold to me as a 2:94 but after doing the spin text I'm thinking it's a 2:76. Has the heavy duty third member or chunk that has the #9 on it. 43" from center to center perches. Zip code 26101. Can meet you half way as long as I have a deposit. asking 1,200. Can take and post pictures if you like.
Craig
