[WANTED] 8 3/4 shock/spring mounting plates
68 Notch Back
Florida
Rating - 0%
0   0   0
I am replacing my 7 1/4 a-body rear end with a b-body 8 3/4 and need the shock/spring mounts. I also need the brake line splitter/vent tube connector
Thanks
The threaded vent tube that holds the flex line or the flex line?
This vent tube is on the rear end housing and vents to the inside of the housing. It also acts as a holder for the Y fitting that splits the brake line coming from the front to the two rear wheels.
