[WANTED] 8 3/4" suregrip assembly in CT area
MRGTX
CT, USA
Rating - 0%
0   0   0
Looking for a plug and play solution for my Dart Sport. Please drop me a PM with the details. Ideal would be a 489 case, 4.5" bolt pattern axles, 4.10 ratio.
Thanks!
Mike
do you have your blown rear end and just want a pig = 3rd member or are you looking for whole rearend with axels and all I can get a 4:10 sure grip for about 750.00 + shipping
650.00 for a 1 leg pegger most will be 741ns in that gear if youneed it all , drum to drum with axels and all you should just call mossier there about 1500.00 ican get posi pigs just call jon 1 608 837 4427 , leave message if I don't catch it right away
Thanks, Winston.
I have the next best thing to a blown axle- a 7.25"(with a 2.73 ratio!). Yep...trash. :) It won't live long after my engine swap...
8.75" 741 case probably won't do the trick.
I will give a call though. What does shipping usually cost? It would be along drive from CT.
I have a suregrip with a 4.? ratio. (I'll have to pull it to be sure what gear it is) I believe it is a 741 or 742 case. If you need an entire rear differential, I have housings, but only SBP axles. I can order LBP for decent price, but it ups the cost of the differential. Please PM me if interested. I'm in Tennessee, but will be going to Carlisle (booths K152-154). I will have several A-body setups with me.
