[SOLD] 8.75 3.91 center section 741 case, sure grip
737jetdr
Martinsville, In.
I have a nice center section that I will not be using. 741 case 3.91 gear set sure grip. Worked fine when removed. Asking $450 plus shipping. Shipping will be pricey as it is heavy. I'm guessing about 75lbs. I was going to remove the sure grip unit to put in my 3.55 center section but don't want to pull apart a good working unit. I will consider a trade for a 3.55 sure grip unit in good working condition. Located in s.e. Michigan 48191. Thanks. This has the large yoke.
Unfortunately other deal is already in the works. Don't want any hard feelings. If it doesn't work out I'll give you a shout. Thanks for the offer.
