[FOR SALE] 8.75 Stuff
whitepunkonnitro
Murfreesboro Tn
Rating - 98.2%
162   3   0
Left hand Ring Gear Bolts $25/set
Adjuster Collars and Lock Tabs $30/set
Empty 741 Case $60
Pinion Snubbers $30
10 Spline, small joint Yoke $30
Fine spline yokes $25
2.94 489 gears $40
10 inch BBP Backing Plates $50/set
11 inch Backing Plates $50/set
Have tons of odds and ends. PM me if interested. Thanks FABO!
Empty 741 Case $60
Pinion Snubbers $30
2.94 489 gears $40
I need an A body 8 3/4 housing. Is that what you are offering? 52 1/2 inches long?
Empty 741 Case $60
Pinion Snubbers $30
2.94 489 gears $40
any extra lock tabs? I need (2)
Hey Tony are the gears in good shape? Do you have the shim that was used with them? If you could post a pic or two I'd appreciate it. Thanks, Tracy
Empty 741 Case $60
Pinion Snubbers $30
2.94 489 gears $40 Do you still have these gears for the 489 fine spline?
Do you still have these 2.94 gears for the 489? Fine or coarse yoke? Sorry don't know how to PM you. - Kelly.
