9 inch hard line
elvaliant66
EL MONTE ,CA
Anyone know if anyone sells the small hard line that goes from the front wheel cylinder to the rubber flex hose . It's about 2 or 3 inches long with a loop in it. Curious to see if someone makes it or I have to just make my own with a standard steel line. I was freshening up my flex hoses on my 67 valiant and fittings were rusted as fu** so the fittings stripped even as I was trying to be super careful .thanks in advance!!
Probably easier and cheaper to bend one. The steel sections they sell in the store are hard to bend. I use the rolls of tubing much easier to do tight bends in. Auto parts have the tools to loan if you do not have them.
Check with Fine Lines. They came in a kit when I did my 67. They may sell the item separate.
Also try Classic Tube.
