90 degree filter adapter
ernie flores
san antonio, texas
which gasket should I use for the adapter the kit has two one looks like the air cleaner gasket and the other looks like a peace sign but it seems when I only put one it is still loose and what about the bolt does it take a cork on it? the engine I am restoring is a 340 which is going into a 68 fastback barracuda.
Test fit the gasket to the sealing area to make sure that it matches....
the peace or Y gasket is for the straight on filter plate and threaded sleave. some rebuild gasket kits may not have the thick cork inner gasket for the 90* mount bolt, and some may not have the thin outer 90* bolt gasket. I use mopar p5249320 gasket kit
today I tried to prime the engine but the oil came out of the 90 degree adapter I tried both gaskets then one then the other and also smashed the bolt cork gasket trying to get them tight but still leaked out. I'll try to order the gasket kit you recommended.
