Will a 904 from column or floor shift hook up to 64 dart pushbutton?
You didn't state six or V-8, they have different cases. Any cable operated transmission should work.Will a 904 from column or floor shift hook up to 64 dart pushbutton?
Possibly. The only option is a 1965 cable operated 904. That said, you'd need the driveshaft from the 65 as well because the 1964 would still have the flange style driveshaft and the 65 and newer are slip yoke style driveshafts.Will a 904 from column or floor shift hook up to 64 dart pushbutton?
Do I? Yeah, 3 of them.Do you have a cable shift tranny now?
