904LA or not
Bob D
Member
TN
I recently purchased a used what I thought was a 904 transmission for my 1965 barracuda with a 273 v8 with a 2bbl. stamping on the main body of the transmission is 246 4450
below that is 3 64 than a D
C D
Tail piece stamping is 246 4690 below that is D D
C D
I don't know if I bought a 727 or a 904. The guy I bought from said it came off the 273 1965.
I wondering if it will bolt up to my 273.
Most likely it's a 904, either trans will bolt up if for a small block. The early 273's up to 67 have the small diameter crankshaft register and require the small diameter snout torque converter. 65'
Thanks all I did find the stamping on the casing A 904 LA. The only thing difference is where the transfer point of the kick down linkage is mounted. The one in the car now is mounted on the chassis . The tranny I just acquired mounts the Side of the bell housing. Thanks again everyone.
