Hey guys,
I need you all to talk some sense to me about my novice knowledge about Mopars and motors. I have a 71 360 on my engine stand. I never heard it run but look's to be low mileage. I pulled the oil pan replaced the oil pump and pan with a center sump piece. The issue I have is it has 973 318 heads on it. It was rebuilt at some point because the rods have their respective cylinders punched on the caps. Looks like stock replacement pistons because they have the pentastar on them.
My issue is I have my eyes on a set of 2.02 1.60 915's that already been gone through and ready to bolt on for 400.00. There's also a pair of 587 1.88 1.60 for 150.00 but might need to be redone. This motor has come from an RV with 727 trans. I have no idea what the cam and stall is and I already want to by the heads and replace the 973's. I also have a set of 340 exhaust manifolds 21/8th outlet.
My practical thinking for drivability is leave the 318 heads on and throw a performer w/600cfm carb on there and run it. I know it will probably run good but be out of breath by 4500 rpms. This is going into my 67 barracuda. I was thinking a dual pattern cam either lunati or comp ex268 something along those lines if I get the bigger heads with a RPM manifold.
If I pull the heads I will have a better idea of it is overbore and a better observation of the cylinders condition. Will the 915's or 587's kill compression on a stock 360? I'm sure the 973's I already have probably make up a 1/2 a point or so for compression.
I hate to pass on good parts and find out later my engine is a dog. Not really sure what I should do guys mind you I still have the rest of car to deal with like upgrade the 71/4 and brakes drive shaft. You know the usually swap stuff.
Thanks guys in advance and I'll leave with .What would you do?
