92-95 magnum harnesses
393foureyedfox
louisville, ky
I make harnesses to put 92-95 5.2 and 5.9 magnums into older vehicles. Ive had this setup on my 66 Fury for 3+ years now. I only do the 1992-95 setups. For more information, PM me. I make them on an as-ordered basis. Feel free to ask questions!
Doug
Is it wrapped and what kind of money are we talking about ? just started on my Daughter's 65 Barracuda swap.
What is the differance for a 90? I have a 90 model P/U 5.2 . The thought has crossed my mind of installing it in my 65 Valiant. I have 3 0r 4 options if there was only one option it would be much easy'r.
Thanks
Can you mod for boost/turbo up to say 10 psi?
you'd likely have to have the computer reflashed. There are a few places you can find online that do that, I don't.
Thanks
the 90 was a throttle body injection, not a Magnum.
so i have a 94 5.2 out of a van... would i have to supply you with a harness to modify or do you have them to sell?
what all need to be done to hook it up? i assume its power,key power ground and fuel pump.. what else?
I havent heard from you in a while Doug,I hope you are doing well.Ive seen these and they are pretty nice.............................................Jeff
so i have a 94 5.2 out of a van... would i have to supply you with a harness to modify or do you have them to sell? what all need to be done to hook it up? i assume its power,key power ground and fuel pump.. what else?
I can do either, but it's usually cheaper on you, due to shipping, to just get one directly from me. Currently, I just make them on an as-ordered basis. If you want one, just let me know.
nice pics! Mopars and fox body Mustangs.....just like me
Good to hear from you, Jeff. I left our old employer a while back after finishing school and started at a local hospital. Other than my Fury, I pretty much just tinker with the Mustang now. I'm sure I'll run into you sometime, if not the next Nat's.
That Dart still needs a Magnum!:burnout:
