I'm in the planning stages of a magnum swap (since I'm stuck on the boat and can't do any hands-on car stuff), and I'm wondering if these two will play well together. My motor is a '97 5.9, complete with harness, computer, fuse box, etc...about everything under the hood of the truck came out with it. I'll be using a '92 a518 w/ lockup as I want to run my stock speedo with a cable, and I was going to use an inline VSS sender like the one below so the trans would still be controlled by the PCM. However, what I've found through web searches says that the cable adapter unit provides a small A/C voltage analog signal, while the 46re style uses a Hall Effect sensor for a digital signal. I'm just wondering if the OBD2 computer will work with what I'm afraid is an OBD1 specific transmission.
