93-95 Jeep Cherokee exhaust manifold
halfhemi
Original Member
N.Seattle
I've seen this thread before about fitting a Cherokee manifold.
Well I finally got my hands on one of the 93-95 Cherokee drivers side manifolds to see if I can fit into my Duster. Well the answer is no. There is no way to run a pipe off of the bottom, even with a mini starter. The clearance is 1.875 inches from the outlet to the starter. Also, my power steering box had to be removed to fit the manifold as it is clearly in the way.
