I know it's not an A body, but I can't really work on my Duster until I fix my sons Jeep. He's deployed and I have it at the house, needs to be shipped to Hawaii in a short while.
I'm chasing my tail here on this one, maybe I can't see the forest through the trees. I had the battery tested, two years old, checked good. Alternator is putting out 14.4-14.6. I put a light in line with the positive cable, barely lights the filament so I start removing fuses in the engine compartment, only one that makes the light not light at all is the Ignition 40 amp. I hook up my meter to test current drain and I only have a 70 ma drain, shouldn't that be okay? What's really confusing me is that I have pulled all of the inside vehicle fuses that the 40 amp engine fuse box feeds and I can't find the source of the 70 ma drain. The circuit goes through the ignition switch which I have broken the connection to, still have that drain. What am I missing?
