1. el5dart
    el5dart Well-Known Member
    569
    383
    May 16, 2018
    memphis, tn.
    Local Time:
    12:36 AM
    i took my first drive on the highway last night and drove about 1 mile to a car show tonight. just needs more money and a little tinkering to finish it up.
    anyways it went from this to this so far.
    • Like Like x 5
    • el5dart
      569
      383
      May 16, 2018
      memphis, tn.
      Local Time:
      12:36 AM
      few more
      • Like Like x 6
      • el5dart
        569
        383
        May 16, 2018
        memphis, tn.
        Local Time:
        12:36 AM
        the car was stripped to bare metal and totally disassembled
        things i added that were not original are:
        air conditioning
        70' rallye dash
        4 speed and a b body pistol grip shifter
        74' non vent window doors and door panels
        sport mirrors
        69 glovebox door
        spool k member
        cop car wheels
        silver paint
        1 1/8 front sway bar
        disk brakes up front
        fender mounted turn signal indicators
        x heads
        hp 68 exhaust manifolds
        tti x pipe manifold back exhaust
        torker 340 intake
        edelbrock 650 carb
        mini starter
        bullet cam
        i did everything myself except install the front glass. and it turns out i am not much of a bodyman/painter. it will lokk better when i can cut and buff it though i think.
        • Like Like x 3
        • 512Stroker
          512Stroker We are all here because we are not all there.
          1,968
          1400
          May 30, 2016
          Freedom, MO
          Local Time:
          12:36 AM
          Just so you know.
          They are never 100% done.
          • Agree Agree x 4
          • 67Dart273
            67Dart273 FABO Gold Member FABO Gold Member
            46,607
            14481
            Oct 14, 2010
            Idaho
            Local Time:
            10:36 PM
            Just a thought. You need to shit can that "air filter" and get a real one. It has turned your 4bbl into about a 1 1/2 bbl, and I'm not kidding. Have you done a WFO (Wide Friccckkin Open) run without it?
            EDIT LOL I guess I was looking at the "before..........."
            • Agree Agree x 1
            • el5dart
              569
              383
              May 16, 2018
              memphis, tn.
              Local Time:
              12:36 AM
              yeah its a 2bbl cleaner i converted to 4bbl cuz i went broke on the budget. been looking for one though. what kind do you recommend?
            • el5dart
              569
              383
              May 16, 2018
              memphis, tn.
              Local Time:
              12:36 AM
              i was going to go for a first drive this past sunday but the alternator took a dump. turns out they are hard to come by. so i took it and had new brushes put in it for 10 bucks. and i had a spare single pulley 100% rebuilt to look like new with a double pulley added in place of a single pulley for 50 bucks. i didnt know roundback two fields were so scarce. not a one to be found at any parts store near me and the ebay prices for a used one were sky high.
              if anyone needs their original alternator or starter rebuilt i recommend
              Dave's Armature Service on jackson ave. in memphis tn. very reasonable prices.
            • el5dart
              569
              383
              May 16, 2018
              memphis, tn.
              Local Time:
              12:36 AM
              i actually used the base off of the air cleaner in the before picture when i converted the 2bbl cleaner till i can find one. it still probably hurts performance i would guess.
            • circlepilot
              circlepilot FABO Gold Member FABO Gold Member
              814
              605
              Nov 15, 2014
              El Dorado, Arkansas
              Local Time:
              12:36 AM
              Your car looks great!, I hope to have my drivable in the next 6 months. The machine shop called today and said my block, head and crankshaft are ready to pick up. I can relate to that "broke" feeling.
            • RustyRatRod
              RustyRatRod Lemmie see your b00bs. FABO Gold Member
              67,776
              42083
              Jun 7, 2010
              Georgia
              Local Time:
              1:36 AM
              I like how you approached this. I like the stock look. What engine is it?
            • el5dart
              569
              383
              May 16, 2018
              memphis, tn.
              Local Time:
              12:36 AM
              its the stock 318 28k mile motor out of the rusty B5 blue car in the pictures. i put ported X heads, Bullet cam, crower Double roller timing chain, HV oil pump, eddy 340 torker, eddy 4bbl, hp 68 manifolds. still running points
              i bought the cam and lifters for a 100 bucks from a guy that only ran it once on his 340 on a run stand. turns out its a regrind. i had to put valve lash caps on it to quieten up. it has a little bump to it but nothing radical. the cam card says @.050 217,221, @.006 272 276, 454 lift, 112 separation.
              i dont know much about cam selection but i think there is a better cam for the motor. i only bought this one sight unseen/unknown because it was cheap.
            • RustyRatRod
              67,776
              42083
              Jun 7, 2010
              Georgia
              Local Time:
              1:36 AM
              "Somebody's" 262 grind would be good. OR is you can find one a Comp 265DEH would be fantastic.
            • RustyRatRod
              67,776
              42083
              Jun 7, 2010
              Georgia
              Local Time:
              1:36 AM
              Also, FWIW, there are better intake manifolds out there. I'm a firm believe in using what you have, though, so I would make the best of it until you can upgrade.
            • el5dart
              569
              383
              May 16, 2018
              memphis, tn.
              Local Time:
              12:36 AM
              that intake is on there because it has bigger port size and provisions for mounting the A/C and it was cheap. but you nailed it. its what i had until i can level up one day. i saved the numbers matching block to this car in hopes of making a stroker motor out of it one day.
              • Like Like x 1
              • deviledchin
                deviledchin FABO Gold Member FABO Gold Member
                350
                65
                Mar 15, 2012
                Sellersville,Pa
                Local Time:
                1:36 AM
                El5dart, what are your plans with the b5 blue dart? I am looking for a complete set of blue seat belts if it had them and you were looking to sell them? Just throwing it out there. I was going to message you but your inbox is full.
                Thanks, Carl
              • el5dart
                569
                383
                May 16, 2018
                memphis, tn.
                Local Time:
                12:36 AM
                the interior in that car is white and black, no blue.
              • deviledchin
                350
                65
                Mar 15, 2012
                Sellersville,Pa
                Local Time:
                1:36 AM
                Sounds good, thanks. I'll keep looking.
              • rdunnam
                rdunnam RDunnam
                63
                14
                May 31, 2011
                Tupelo, MS
                Local Time:
                12:36 AM
                What a transformation! That's nice and it shows the hard work it takes to bring one up. Looks great. There's a single handful of Mopar folks here in Tupelo, you have a gang of them in Mempho? I'd like to connect up w/some more.
                I'm looking for another A-body, working on pickups now, but want another Dart, Duster, Valiant...something. el5dart, keep up the good work!
              • el5dart
                569
                383
                May 16, 2018
                memphis, tn.
                Local Time:
                12:36 AM
                there is a mid-south mopar club here not sure what they are up to lately.
                • Like Like x 1
